Brake Bleeding Issues
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Brodie, Nov 23, 2006.
  1. Brodie
    Brodie 1/2 ton status
    Mar 20, 2006
    255
    Puyallup, WA
    I changed the wheel cylinders on my truck today and have run into a few snags. While we were bleeding the brakes we accidentaly cavitated the
    MC reservoir. :doah: We refilled the reservoir and pressed on. Unfortunately we got absolutely no response from the brakes anymore. No fluid out of the bleed ports and no pedal movement when the ports were opened.
    Before the cavitation we were moving quite a bit of fluid through the lines, and still getting air. We cracked the line at the MC and applied the brakes. Nothing came out. I started the truck up, and the brake light came on and wouldn't go out. I'm leaning towards a bad MC but I was hoping for some advice from the masters. Thanks
  2. SLOK5
    SLOK5 1/2 ton status
    Apr 25, 2005
    216
    SAN LUIS OBISPO CA
    :wink1: The best way is to let it gravity bleed. Fill the master cylinder up and open all the bleeder screws and let the fluid run out for awhile. This should solve your problem.
  3. sweetk30
    Nov 1, 2004
    25,536
    533
    horseheads , ny 14845
    you might want to pop on a new master. you mostlikly trashed the seals when you went full drop. as the master dosnt normaly go this far in everyday travel. but you could try bleading it like a new master first.
    best why to blead brakes i have found over the years in the bissness is pump slow and steady not super fast. and 3 pumps and hold is about the best for the pressure to pump ratio. seems to work super for me.
  4. Brodie
    Mar 20, 2006
    255
    Puyallup, WA
    I R2 the MC today and bled the crap out of the entire system. Lo and behold it fixed it!!!! Even the light went out.
  5. AZ79K5Project
    AZ79K5Project 1/2 ton status
    Jan 15, 2006
    2,082
    Arizona
    "R2" ???
  6. Brodie
    Mar 20, 2006
    255
    Puyallup, WA
    Remove and Replace
  7. AZ79K5Project
    Jan 15, 2006
    2,082
    Arizona
    Thx
