brake bleeding problem....
Discussion in 'The Garage' started by chevyfumes, Jul 20, 2002.
  1. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
    I was taking the rear dif cover off for inspection and I losened the rear brake line ( hard line going to the wheel) by moving the bracket outta the way of the cover. Now I can't seem to bleed the brakes or even tighten it up enough to keep it from leaking. Do you have to bleed it from that section and not the wheel, if so how.... /forums/images/icons/confused.gif /forums/images/icons/confused.gif /forums/images/icons/confused.gif tired of no pedal! /forums/images/icons/blush.gif /forums/images/icons/wink.gif
  2. chulisohombre
    chulisohombre 1/2 ton status
    Apr 11, 2002
    4,140
    14
    Bangor,Pa
    you should try and fix your leak first and then go from there.
  3. fr8train
    fr8train 1/2 ton status
    Aug 2, 2000
    1,712
    Maryland
    How much fluid came out? Yeah, I agree though fix the leak. After that I would just go the normal bleeding of everything.
  4. chevyfumes
    Feb 24, 2000
    38,584
    266
    I understand , but do you need to bleed it from where it's leaking also, or will it eventually get pushed out the wheel opening? thanks guy's... /forums/images/icons/crazy.gif
  5. fr8train
    Aug 2, 2000
    1,712
    Maryland
    I am thinking that you should just fix the leak. It could suck little air bubbles in. I would bleed at leaking side at the wheel.
  6. chulisohombre
    Apr 11, 2002
    4,140
    14
    Bangor,Pa
    every time you push on the brake pedal and the brake return springs push back on the wheel cylanders you are more than likely like fr8train said getting air bubbles back in the system.that means until you fix the leak in the system you will never get the brakes to bleed properly
