Brake Bleeding Problems -- Any advice?
Discussion in 'The Garage' started by Russell, Mar 26, 2007.
  1. Russell
    Russell LB7 Tahoe Status Premium Member GMOTM Winner
    Jun 23, 2000
    7,922
    333
    Fort McMurray, Alberta
    Hey guys!
    A friend of mine was out on the trail yesterday and blew a seal in her master cylinder. I brought her out to my place to change the M/C out, which is a pretty typical job. I made sure to bench bleed it, and didn't get any more air out of the M/C before installing it. I bolted it on, then bled the lines as they go into the M/C. Got all sorts of air out, so I kept going till the air stopped. Tried the truck, and the pedal goes straight to the floor.
    I then bled the whole system, and got a bit of air out, but nothing remarkable.
    Truck's pedal still hits the floor, and has very little braking force.
    Does anyone have any suggestions of what may be up with the thing? Its a 95 fullsize Bronco BTW
    Thanks!
    Russ
  2. shane74
    shane74 1/2 ton status
    Feb 12, 2002
    4,100
    Vancouver, WA
    Odds are you still have air in the system. Try bleeding the brake system a couple more times. You might be suprised at how much air gets into a system when you swap out a MC.
  3. dremu
    Feb 27, 2000
    15,954
    445
    East of San Francisco
    Bleeding brakes is a miserable, slimy, evil job.
    Pressure bleeding with the garden sprayer is the only thing that's worked for me, as I'm too impatient to gravity bleed and I can never find a buddy to do it the old fashioned, two-man way.
    -- A
  4. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Its easy to do solo with a piece of tubing and jar of brake fluid . Simple and sweet solo brake bleeding .
  5. Russell
    Jun 23, 2000
    7,922
    333
    Well, my bleeding wasn't the problem -- The drum's spring system fell apart somehow... Took the drum off, and all the parts and peices fell down on the floor, LOL
    Fixed the drum, put it back together, and dang, suddenly we've got a heck of a stiff pedal!
    Then went to bleed my GMC's brakes since we were already covered in brake fluid, and something is horribly wrong. Back brakes bled alright, went to do the fronts, and it puked out some puss covered crap, and I lost my entire pedal, no brakes at all. Front is full of air :doah:
    No idea what happened, but it certainly is frustrating. I'm thinking I'm going to pick up a fresh 3/4 ton 4x4 to drive for the summer, and re-start my GMC from the frame again, doing it properly from start to finish...
