brake bleeding
Discussion in 'The Garage' started by erin3183, Feb 16, 2004.
  1. erin3183
    erin3183 Registered Member
    Feb 13, 2004
    8
    I have an '89 chevy 4x4 that has a leaking master cylinder. I have a repacement that I am planning to bench bleed and install. At the same time I want to flush my brake system by opening all of the bleeder valves to gravity bleed while keeping the reservoir filled with new fluid. I have read quite a few articles but haven't got a clear answer on whether or not doing this is a sufficient way of getting the all of the air out? Will the air trapped from the MC swap be removed by gravity bleeding? Any help would be greatly appreciated.
  2. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,092
    492
    Grand Rapids area
    I don't even know if gravity bleeding is possible. Have the lines coming from the M/C open for as little time as possible and if you can, have something ready to plug them while you change the M/C. The less air you get in them the less there is to bleed out. To flush the fluid, why not just do it the old fashioned way by opening the bleeders one at a time an pumping the pedal?
  3. erin3183
    Feb 13, 2004
    8
    I actually had no intention of flushing the entire brake system until I began searching for the best way to swap out MC's. Thats when I found out that the fluid degrades and absorbs water over time and should be flushed as often as every 30k miles to remove contaminants, prevent brake parts corrosion and maintain performance. I figured now is the time to do it since I have to bleed the system anyway and to my knowledge this truck has never had a flush in it's 140,000 mile life. I'd never heard of this before, but just about every article I read said "gravity bleeding" was the best way. Open all 4 bleaders and let the fluid run out them, close each as you see the "new" fluid come out, making sure to keep the MC filled at all times with new fluid. I just want to be sure that I get the correct end result.
  4. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    When I swaped my in 3/4 ton axles, I had to bleed the rear brakes. I used the gravity bleed method. I just opened up the rears one at a time and let them bleed until the fluid was clean and bubble free. Of course I kept the MC fluid level up like you described and it worked quite well.
    I will most likely gravity bleed the fronts once I put the extended lines in. /forums/images/graemlins/waytogo.gif
  5. Can Can
    15,555
    156
    Cochrane, Alberta, Canada
    Gravity bleeding is indeed possible. That's the process I've used everytime, and it works like a breeze. I'm sure there are better ways of bleeding if you have a lot of air in the lines, however.
  6. erin3183
    Feb 13, 2004
    8
    Cool, thanks for the feedback
  7. gravdigr
    gravdigr 1/2 ton status
    Apr 15, 2003
    1,129
    Tyrone, PA
    I use one of those mityvac hand vacuum pumps. It works well. You hook it to your bleeder and it sucks the fluid through the system and into a resevior. Advantages are 1 man job, no mess, faster than gravity bleeding if you are in a hurry.
  8. lukebaby1
    lukebaby1 1/2 ton status
    Dec 16, 2003
    231
    Richmond, Virginia
    /forums/images/graemlins/peace.gif /forums/images/graemlins/peace.gif /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif Here you go www.phxsyss.com
  9. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    I have found gravity bleeding to work the best when there is no fluid in the lines. Be warned it takes a while to do it the gravity way. When I did my axle swap it took about 30min to get fluid to the rear brakes.
  10. landcrusher
    landcrusher Registered Member
    Jan 21, 2004
    33
    Escondido, CA
    I use a vac bleeder also. Big plus for one man operation. The only drawback I have experienced is that air is sucked past the bleeder threads. Sometimes it's hard to determine if air is from the line or from the threads.
  11. gravdigr
    Apr 15, 2003
    1,129
    Tyrone, PA
    rub some petroleum jelly around the bleeder when you open it. Fixes that problem...also seems to keep the bleeder from seizing to the caliper.
  12. landcrusher
    Jan 21, 2004
    33
    Escondido, CA
    Good tip. I'll have to try that next time.
