Brake booster and master cylander question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Seventy4Blazer, Dec 16, 2002.
  1. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    what is the newest brake booster and master cylander i can put in the wifes 76 jimmy?
    hers is leaking bad and i have been told that the newer plastic ones work GREAT. but what year to use?
    Grant
  2. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    You can use most of the newer ones. They will physically bolt up - but odds are your master has SAE threads, and the new ones have metric, so you'll probably have to get a couble of metric flare nuts and a flaring tool to make it work.
    I took a master from a '93 K2500 and bolted in onto my '91 crewcab. I'm not saying its 'correct', but it works just fine. /forums/images/graemlins/wink.gif
    For a '74 Blazer, I'd check to see if a '91 Blazer is aluminum - if not, go with a 92 - it will be aluminum for sure.
  3. Seventy4Blazer
    Apr 21, 2001
    5,634
    Escondido, CA
    thanks, its for the 76 jimmy.
    i like the clear ones. i can see the fluid level. im to lazy to open it some times, and the way it leaks now i almost forgot to check it the other day... kinda not fun ya know.
    Thanks again. anybody else?
    Grant
