Brake booster...how to know if good or bad?
Discussion in 'The Garage' started by MTBLAZER89, Sep 27, 2004.
  1. MTBLAZER89
    MTBLAZER89 3/4 ton status GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    Brakes work but not good. Have to liteally stand on the pedal just to get it to slow down /forums/images/graemlins/yikes.gif Is there a way to troubleshoot this? What are the symptoms of a bad booster or a bad MC? Any ideas?
  2. Poohbair
    Poohbair 1/2 ton status
    Jan 30, 2003
    2,139
    Ellensburg, WA
    for the booster you should be able to start it and let it run for a few. shut it off and let it sit for a few minutes, maybe 5. Then pull the vaccum hose off the power booster. You should here a swoooooooosh of air. If not, then either the diaphram in the PB is bad, or the 1 way valve that pushes into it is bad. It has to hold pressure to work.
    As for the master cyl, cant help ya! /forums/images/graemlins/screwy.gif
  3. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    If an m/c goes bad, your foot will go to the floor, so thats ruled out. If your booster is bad, it literally have to STAND on the pedal for the brakes to even think about stopping.
  4. ksblaze83
    ksblaze83 1/2 ton status
    Sep 11, 2004
    329
    Topeka, KS
    ttt....if there is fluid in the booster, does that mean the booster is bad? /forums/images/graemlins/thinking.gif
  5. mtnman210
    mtnman210 1/2 ton status
    May 30, 2003
    3,880
    Northridge, Ca
    I just had the same problem. My pedal was hard as a rock and my truck didn't stop very well at all. It ended up that when the master cylinder had gone bad a few weeks before, it had leaked into the booster which caused that to go bad. I've since put in a new M/C and brand new booster and haven't any more pedal problems. plus the brakes are awesome now. So my suggestion for what you described would be a new booster.
  6. dyeager535
    26,980
    Factory test is to start the truck, don't touch the brake pedal. Let idle for a few seconds (longer won't help) turn truck off, again without touching pedal, wait awhile (can't recall the time, 5 minutes should be enough) then try the pedal. You should have a MINIMUM of 2-3 fully assisted brake applies before the assist disappears.
    Dad had a booster go bad in his truck last year, interesting to try and stop is an understatement. Quite an expensive piece too.
  7. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    if the booster does not hold enbough vaccum for 2 or 3 pumps of the pedal after just turnig off engine then its bad
    thgats about the only way to test a booster,
    and havngi to stand on pedal hard definitely sounds like fubar booster, for sure
    good luck
