Brake bracket
Discussion in 'Parts & Trucks Wanted' started by BLZN4FN, Jan 15, 2005.
  1. BLZN4FN
    BLZN4FN 1/2 ton status
    Dec 19, 2000
    1,720
    Englewood Colorado
    Need brake drop down brakets that come with most lift kits.
    Its the bracket the moves the brake line from through the frame
    to the bottom of the frame.
    Let me know,
    Bo
  2. sweetk30
    Nov 1, 2004
    25,537
    535
    horseheads , ny 14845
    bracket info
    i took the factory one off the frame and cut the end off were the rivets go to the frame and drilled a hole in the center section, then re atached to the bump stop bracket . i was running 4" lift and wouldent hit the stops any more and thay had fallen off any way. try this. i havent seen any drop brakets before except for the ebrake lines .
  3. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    I have some from my lift that are just 90 degree brackets with a large hole on one side for the brake line and a small hole on the other for the bolt. I also have a straight flat one for the rear. I will be able to check on Monday to see if I still have them and get a pic to you. You can have them for free if you want, you just pay shipping.
  4. BLZN4FN
    Dec 19, 2000
    1,720
    Englewood Colorado
    please let me know what you have and where to send you some money for shipping.
  5. B_to_C
    B_to_C 1/2 ton status Author
    Jan 15, 2003
    1,861
    In Government Housing
    Hey Bo,
    I don't have drop down brackets, but I wish I had a passenger side door :whistle:
    Since PM's don't seem to be working :what: maybe just call me? 978-505-1401
    -Nick
  6. divorced
    Jul 20, 2004
    5,115
    ok, and I sent ya' a pm.
  7. divorced
    Jul 20, 2004
    5,115
    The angle brackets measure about 1 3/4" x 1 3/4" and the flat one for the rear is 4" long. Let me know if they are what you were looking for.
