Brake Cables
Discussion in 'The Garage' started by AkMudr, Mar 15, 2005.
  1. AkMudr
    AkMudr 1/2 ton status
    Dec 30, 2004
    917
    Alaska
    14bSF and 14bFF use the same parking brake cables?
    For mid-80's 3/4ton
  2. mechted
    mechted 1 ton status Premium Member
    Oct 19, 2003
    765
    Granbury, TX
    yep, they use the same ones, the only thing to watch out for is that you get the 82(?) up style ebrake cables, (one cable down driver side frame rail, splits and pass side cable crosses over the pinion) not the older style
  3. dyeager535
    26,979
    Haven't had the pleasure of dealing with the later setups. (I thought the change was in '83, but who knows/cares for this matter)
    However, should be visually easy to tell even with rear axle out of vehicle..."old" style will have two equal length cables, "later" should have passenger side cable much longer so that it reaches to drivers side.
    If looking for rear axles, etc., I'd suspect the cables themselves could be swapped out if necessary, but dang, those clips that go through the backing plate suck to remove.
  4. mechted
    Oct 19, 2003
    765
    Granbury, TX
    well... the cables can be swapped, but you have to to change the backing plate too... they mount differently (early = bolt in, later = clip in) btw, the backing plates are also interchangable :)
  5. AkMudr
    Dec 30, 2004
    917
    Alaska
    I'll be going from an '85 14bSF to an '87 14bFF from a CUCV.
  6. tomseviltwin
    tomseviltwin 1/2 ton status
    Dec 23, 2001
    2,065
    Utah
    You mean the sf and ff backing plates are interchangeable?
  7. mechted
    Oct 19, 2003
    765
    Granbury, TX
    yep, as long as its the same brake size (11.2" or 13")
  8. tomseviltwin
    Dec 23, 2001
    2,065
    Utah
    Cool. Are the brake drums interchangeable too?
  9. mechted
    Oct 19, 2003
    765
    Granbury, TX
    uhhh... i dunno
    i wouldnt think so, because the FF version presses onto the hub, one would *think* its different than a SF... but this is just me thinking, not actually having knowledge
