Brake caliper loose? bolts tight, is there supposed to be an o ring...
Discussion in 'The Garage' started by 90K5, Jan 5, 2003.
  1. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    Is there supposed to be an O-ring on the caliper bolts? Noticed one of them could wiggle around today...took it apart and it looks like there is a notch near the head of the bolt for possibly an o ring? i kinda remember some coming with my pads, and there are some red ones in my toolbox...hmmm...not even sure if it would help...im gonna try swapping out the bushing things too.
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    A small O-ring fits into the hole in the caliper for the end of the bolt. A slightly larger O-ring fits into the caliper on the other side, where the bolt head fits. But there is also a steel sleeve that goes into that side first, before you install the caliper bolt. /forums/images/graemlins/cool.gif
  3. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    I think the O ring is supposed to be in the bushings. Look in the bushings for recesses where the o-ring would sit. Maybe the O-ring was supposed to be in the ear of the caliper. Look there also. Ok Harryh3 beat me to it. He is exactly right.
  4. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    I found a couple of them, enough to do the side that was really bad. It's definatley a lot better now, need to find some more of those to do the other side though.
  5. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    We just put rear disks on a guys Blazer this weekend and the calipers only had the bushings? It was tight too.
  6. LKJR
    LKJR 1/2 ton status
    Apr 18, 2000
    2,116
    Lubbock, Tx
    I think your just spending too much time messing with your truck..you need to go back to lubbock and quite worrying about it till your in witchita falls on the side of the road. /forums/images/graemlins/rotfl.gif
  7. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    Thats crazy and will never happen...I dont take 82. I'll be in like Dickens on the side of the road.
  8. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    Maybe your rear discs were a different design...the new ones definately tightened it up, it doesn't move at all now
