Brake caliper question.
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BLzr4x4ngkid, Jun 12, 2001.
  1. BLzr4x4ngkid
    BLzr4x4ngkid 1/2 ton status
    Feb 18, 2000
    703
    Wichita, KS
    Hey guys, I just put new calipers, pads, and shoes on my truck. The pads are not snug on the caliper. Is there a missing clamp like the inside pad has? The one that goes into the piston to hold it in place? I need to get them fixed ASAP.
    "Don't hit me with them negative waves so early in the morning." Odd Ball--Kelly's Hereos
  2. BlueBlazer
    BlueBlazer 1/2 ton status
    Feb 15, 2001
    1,940
    Its supposed to rock around a little. Mine does the same thing and so do a lot of other brake pads on othe vehicles. There is no clip missing.
    Tyler
  3. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    I take a large set of chanel lock pliers and bend them down to keep them from moving. It also eliminates squeel.
    '71 Blazer CST with alot of rust
  4. nyyef
    nyyef 1/2 ton status
    May 16, 2000
    479
    Saudi Arabia
    as triaged said, just give them a bend to get a grip on the caliper. i installed a set once and they squeeled like hell. i couldnt understand it because they were new. then my dad said that squealing either comes from the wear tab, dirt or because they are loose. they were loose.
    Knife.
    knife.coloradok5.com
  5. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color=blue>The squeal comes from the pad backing (metal part) vibrating against the caliper. You can bend the tabs to quiet the squeal, or theres a specail grease you can get at parts stores that goes on the back of the pad</font color=blue>
    [image]http://bbs.off-road.com/wwwthreads_uploads/53-288682-mudpit3.jpg[/image]
  6. BLzr4x4ngkid
    Feb 18, 2000
    703
    Wichita, KS
    Ok, where in my post did I say it was squeling? hahaha The problem is, it just sits in there and rattles around. It's loose. That's what I was curious about.
  7. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    Are you talking about the pad that's NOT against the piston? I just replaced pads on my truck recently, and I seem to remember the pads did move around a bit. Not much, though...
    <font color=red>Click those banners and help support CK5!!<font color=black>
    [​IMG] Semper Maintenance!
  8. BLzr4x4ngkid
    Feb 18, 2000
    703
    Wichita, KS
    You got it! That's what I was wanting to know. Can I please have your name, address, and what kind of Cuban Cigars you would like. Thanks!
    LOL
  9. BlueBlazer
    Feb 15, 2001
    1,940
    I thought I answered it already. I guess not. Anyway I smoke Backwoods. :) J/K
    Tyler
  10. BLzr4x4ngkid
    Feb 18, 2000
    703
    Wichita, KS
    Sorry Blue! I must have missed your post. I think I wrote my response when I got home from work, at 6am! My bad man! See ya!
