Brake Caliper Question
Discussion in 'The Garage' started by opfor2, Apr 1, 2006.
  1. opfor2
    opfor2 1/2 ton status
    Oct 28, 2002
    375
    Ventura County, CA
    I have a 90 Blazer and my front caliper's are sticking and need to be replaced. I was wondering if I could replace the stock calipers with Severe Duty ones from NAPA? Here's the link to what I'd like to replace them with
    Right Caliper: http://www.napaonline.com/MasterPages/NOLMaster.aspx?PageId=470&LineCode=UP&PartNumber=4422057SD&Description=Brake+Caliper+w%2f+Pads+%26+Hardware+-+Right+Front+(Severe+Duty)+-+Remfd
    Left Caliper: http://www.napaonline.com/MasterPages/NOLMaster.aspx?PageId=470&LineCode=UP&PartNumber=4422056SD&Description=Brake+Caliper+w%2f+Pads+%26+Hardware+-+Left+Front+(Severe+Duty)+-+Remfd
  2. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    SD or not, that price seems a litle extreme. In the past I have paid no more than $17.99 for stock 10 bolt calipers.
    If you want better performance out of your brakes, I would look at good quality pads and rotors.
  3. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    if you figure it up for both loaded calipers, then minus $20 for pads, it come to 17.50 for each caliper. thats a fair price.
    im not sure what is so special about them, unless its in the pads them selfs.
  4. readymix
    May 30, 2004
    6,706
    26
    It looked to me that the price was per side
  5. opfor2
    Oct 28, 2002
    375
    Ventura County, CA
    Yes, the $ 63.49 is for one caliper not both.. I was just wondering if I would get better braking power and reliability from a "Severe Duty" caliper vs. a normal one.
  6. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    The factory calipers in my burb work just fine - I'm not quite sure what the "severe duty" add
  7. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    sorry, for the right side it didn't say a price and for the left side it showed 27.50 so i figured it was the same for both. now it doesn't show anything for either caliper.
    i wouldn't pay more than $20 for one caliper, the local carquest sells them for $16 each.
  8. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    What constitutes "Severe Duty" is what I want to know...
    They add more lip seals?(makes no sense to me)
    Bigger piston?(I truly truly doubt that).
    So what makes it so special? Unless they really change the design of the caliper I don't see any purpose to spending a single cent more on it.
    Are you sure they don't mean "Severe Duty" pads are loaded in it?? If thats the case, DO NOT buy them. I'd bet Severe duty is like "lifetime" or "fleet" brakes, they are junk and wear out rotors before the pads wear out(guess which costs more).
    Just my thoughts on it
