Brake caliper question
Discussion in 'The Garage' started by cbbr, Jun 24, 2006.
  1. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    I have been looking for a set of Caddy calipers. I have a line on a set cheap, but the guy said that they need rebuilding ad have a little surface rust. Is the rust a big deal if its only on the surface? How complicated is the rebuild?
  2. opfor2
    opfor2 1/2 ton status
    Oct 28, 2002
    375
    Ventura County, CA
    NAPA usually sells rebuild kits and there not that expensive. The rebuild is pretty straight forward, new piston seals and what not.
  3. hack500
    hack500 1/2 ton status
    Sep 16, 2005
    523
    Templeton, Ma
    if you get 'em and decide on a rebuild I can take some pics of my caddy fsm that covers the rebuild.
  4. dyeager535
    26,982
    191
    Got a hone that will do the bore too? I wouldn't waste time on a rusty set of calipers unless I was prepared to do a complete, thorough rebuild on them, although I do know how difficult these calipers are to procure.
    As long as you are willing to do them right, no reason they shouldn't work.
  5. cbbr
    Jul 17, 2004
    14,681
    Nope. That is the one thing that I am most worried about. My understanding is that there is no rust in the bore, but I am waiting on pictures.
  6. dyeager535
    26,982
    191
    Corvette calipers (early) didn't have seals on them, and they have a HUGE problem with rust in the bores. If it was open to atmosphere at all, (IE didn't have brake fluid in it) I'd expect the cast iron to have rusted enough to need a hone to guarantee the seals don't leak.
  7. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    If the price is right buy the calipers remove the springs and arms and use them as cores to buy a set or reman calipers from your local autoparts store.
    Ira
