Brake Code
Discussion in 'The Garage' started by daleearnhardt01, Sep 21, 2004.
  1. daleearnhardt01
    daleearnhardt01 1/2 ton status
    Aug 29, 2002
    3,223
    Richmond, VA
    Since the search function is so crappy Ill have to ask here. Buddy has a 89 3/4 4x4 Burby. I forget where to look to find out the brake code (ie. JB7 or JB6..etc) Where is that info at? /forums/images/graemlins/peace.gif /forums/images/graemlins/peace.gif /forums/images/graemlins/peace.gif
  2. TruckNutzDude
    TruckNutzDude 1/2 ton status
    Mar 31, 2003
    3,532
    Agawam, MA
    If you have a 14 bolt full floater in the back it is JB7. If you have a semi-floating 14 bolt the code is JB6. The other way to tell is if you have the 13" drums or the puny 11" ones. /forums/images/graemlins/thumb.gif
  3. daleearnhardt01
    Aug 29, 2002
    3,223
    Richmond, VA
    Interesting...glove box says JB7 but its a SF axle so we shall see when I get it all apart for him..
  4. mosesburb
    mosesburb For Rent Premium Member GMOTM Winner
    Apr 20, 2003
    2,172
    128
    Phoenix AZ
    It should be a JB7 on a 3/4T, regardless of which diff it has. The only relevance I have seen to which diff you got is small blocks got the 14SF and the big blocks got the 14FF, but they all had the same brakes on the 3/4T. This is not gospel, just what I have seen over the years at the shop.
  5. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Well it's wrong. 3/4 tons come with 11 x 2 1/2 or 13 x 2 1/2 brakes. 11" are less common but they're out there.
  6. daleearnhardt01
    Aug 29, 2002
    3,223
    Richmond, VA
    This truck did have JB7 brakes.....
  7. mosesburb
    Apr 20, 2003
    2,172
    128
    Phoenix AZ
    Your information has an inaccuracy in it as well. You stated the 11" diameter drums have a 2-1/2" width when it is actually 2-3/4". These do exist, but I have never got a set of 13" shoes sent back as wrong parts on a 3/4T 4x4. Typically the only time JB6 shows up on a 3/4T is either 2wd or a G-van.
  8. ugly_blazer
    ugly_blazer 1/2 ton status
    Apr 12, 2004
    1,214
    As you said, I had a 2wd 3/4 ton with the jb6 system. I also have never seen it on a 4x4.
