brake combination valve
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by ktedesco, Apr 3, 2004.
  1. ktedesco
    ktedesco 1/2 ton status
    Mar 21, 2004
    365
    Colorado Springs, CO
    Hello everyone. I am new to the board and have found it EXTREMELY helpful. I purchased a 90 K5 a week ago with the intent to build it up. I just installed a 4 in. lift and of course had to disconnect the brake lines. After completing the lift, I bled the brakes and and the dash light is still on, assume I still have air in the lines. I looked into it and Chiltons manual says to open the combination valve. Problem is, I can't find it. Sounds like I am stupid but manual shows it on front left frame near the steering gear. All I have there are the 2 lines coming from proportioning valve and spliting to the LF, RF and rear wheels. Do some models not have the combination valve? Any help is greatly appreciated! Thanks
  2. vegas76k5
    vegas76k5 Registered Member
    Apr 20, 2003
    31
    Las Vegas, NV
    I am not sure about your year, but mine is on the crosmember.
  3. dyeager535
    26,980
    Proportioning and combination valve are one and the same (actually thats why its called a combo valve and not proportioning) on these trucks.
  4. ktedesco
    Mar 21, 2004
    365
    Thanks for the help. I bled the brakes more without doing anything to the combination valve and I seem to have a firm pedal and good braking now. The dash light is no longer on so it should be ok.
