brake conversion capacity
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by elacruze, Nov 28, 2004.
  1. elacruze
    elacruze 1/2 ton status
    Dec 23, 2003
    121
    SE Michigan
    Considering doing the 14 bolt rear disk /Caddy caliper conversion. I have the big one-ton drums; how much braking capacity do the disk conversions have? Will I wish I had more brakes with a heavy load on?
  2. tRustyK5
    Jul 23, 2000
    36,178
    1,387
    E-town baby!
    I had the big one ton drums on my Jimmy for a while...way too much braking without some sort of adjustable prop valve. The rears would lock with moderate pressure and the fronts never would (D60 front, new brakes all four corners)
    I swapped to the rear disc's with D44 calipers on the rear. Now I get no premature lock-up with moderate pedal pressure, but if I hit em harder all four corners lock-up at the same time. That's on 39.5" TSL's too...
    I don't feel like I ever need more braking.
    Your pick-up should have a self adjusting and load sensitive prop valve attached between the 14 bolt and the frame with an arm of some sort. The more weight in the bed, the more braking the rear will see. IMO, if you tow or haul heavy junk this is a great feature. You may be able to keep the prop valve back there and adjust it as needed. If the rears are locking up too quickly, shorten the arm. Not locking up early enough then lengthen the arm.
    Rene
  3. elacruze
    Dec 23, 2003
    121
    SE Michigan
    Thanks a ton (NPI)
    This truck has such heavy rear springs that I'll likely never squat it enough to activate that valve. I get a big DUH tattoo for wondering whether the brakes that stop 5500lbs of 1/2 ton and Caddy are enough for my rear...
  4. tRustyK5
    Jul 23, 2000
    36,178
    1,387
    E-town baby!
    Rear disc's is mostly a win-win conversion. Lose a bit of weight, plus it's a bunch easier to service disc's than full floater drum brakes. Stopping power is good with the disc's, and you don't have to worry about filling the brakes up with mud and ruining them.
    Only drawback is the e-brake headache.
    Rene
  5. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    and those of us with 465s shouldnt have much of a problem without it altogether
