brake convert probs
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Thumper, Sep 2, 2001.
  1. Thumper
    Thumper 1/2 ton status
    1,582
    Alberta Canada
    OK, the discs work great. Except for every once in a while I get this weird groaning/ low pitched rubbing sound from my left rear disc. Its definately coming from the pads, seems like they are rubbing the rotor the wrong way, and the sound disappears right away when I touch the brake. I thought they might be glazed or something, so I wire wheeled them. No change. I thought maybe the sharp corner where they meet the rotor was causing it so I ground the edge off a bit, no change. The rotors are new, as are the pads. My next plan is to trade the new pads with the half worn ones from the front and see if it changes. Would a misalignment of the caliper cause this? Has anyone heard this sound before? How could I fix it? Any ideas?
    Mike
    <font color=blue>Thumper
    85 Fullsize Jimmy
    <font color=red>Aint Skeered!! </font color=red>
  2. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    It could be the caliper is sticking. Pull the bolts off that the calpier slide on and grease them up, and make sure the caliper moves back and forth freely. More than likely thats what it is. What happens when they stick it lets one pad always touch the rotor and will make noise, but when you hit the brakes it applies more pressure and the noise will go away.
    86 Jimmy 4"lift 35"MTRs Other cars 69Firebird w/525 hp,and 70GTO live in PHX,AZ<a target="_blank" href=http://www.geocities.com/modifierperformance>My vehicles</a>
  3. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    Try putting some "Disc Brake Quiet" on the pads - rears seem to vibrate a little more than fronts typically, might be the cause of your noise.
    1 tequila 2 tequila 3 tequila Floor
    <a target="_blank" href=http://pugsley.alloffroad.com>pugsley.alloffroad.com</a>
