Brake cylinder/ drum removel HELP PLZ!!!!!!!
Discussion in 'The Garage' started by Chrisblazzer89, Feb 8, 2007.
  1. Chrisblazzer89
    Chrisblazzer89 1/2 ton status
    Oct 12, 2006
    1,966
    Massachusetts 02301
    How hard is it to replace a brake cylinder on a 14BFF my bleeder screw thing broke and now i cant bleed my driver said rear drum and its full if air so it wont work. SO i know I need to pull the axle shaft, drum, shoes, springs and crap, then do I just unbolt the old cylinder and pop on the new?
  2. sweetk30
    Nov 1, 2004
    25,526
    526
    horseheads , ny 14845
    basicly. and dont forget a new axle seal. hate to see a used one go back in and then puuke oil in a week or 2 on the shoes.
  3. Chrisblazzer89
    Oct 12, 2006
    1,966
    Massachusetts 02301
    how hard is that to do?
  4. sweetk30
    Nov 1, 2004
    25,526
    526
    drums off so just pop it out and back in like any other seal.
  5. Jason4x4
    Jason4x4 1/2 ton status
    Nov 5, 2006
    4,505
    6
    Chandler, AZ
    you don't need to pull the shoes off, hust take the top springs off, and slide them out of the way a bit.
  6. Chrisblazzer89
    Oct 12, 2006
    1,966
    Massachusetts 02301
    Cool thanx I would of pulled them all the way out if some one didnt say something.
  7. Chrisblazzer89
    Oct 12, 2006
    1,966
    Massachusetts 02301
    [​IMG]Is there a tool remove this? Do i need to remove this to remove the drums? Or are my brake shoes just loosely engaged? ANY advice on how to remove my drums?
  8. Goose
    Goose 1/2 ton status
    1,127
    South Central Kansas
    Yes you need to remove that big nut.
    If you don't have the tool, I've put a punch in one of the groves and hit the side of the punch with a hammer to start it off.
    It usually doesn't take much.
    Also, some parts store will rent/loan you the tool.
    There are several variations to the 4 prong pattern, so if you go the parts store route make sure you get the right kind.
  9. Goose
    1,127
    After you take the nut off you'll get to the outside wheel bearing. I usally fish it out so it doesn't fall off in the dirt when I pull the drum.
    If the drum still won't come off, you may have to back off your brake drums.
    That is done on the back side on the bottom. There will be a small oval hole you can slip a screw driver (or similar tool made for that) and turn the star wheel that adjusts brake tension. I can't remember which way it turns tho.
  10. Chrisblazzer89
    Oct 12, 2006
    1,966
    Massachusetts 02301
    It has 6 groves not 4
  11. Goose
    1,127
    About the seal. It will be on the back inside of the brake drum. Just inside it is the inner wheel bearing. The seal comes out easy enough. Another large screw driver and gently pry it out.
    Inspect both wheel bearings for pitting and other marks or discoloration.
    The new seal goes in easy if you have something about the same diameter you can put over and use as a punch. I never do, so I put it in place nice and square and gently tap around it clockwise with a brass hammer. Be careful not to bend it all up. A little oil helps it go in straight.
  12. diesel4me
    Jul 24, 2003
    17,534
    920
    Massachussetts
    I cheat!..
    Sometimes you can get lucky and bleed a wheel cylinder with a busted bleeder screw by loosening the steel brake line at the wheel cylinder,instead of at the bleeder...
    You may not get 100% of the air out this way,but I've been able to limp home with "so-so" brakes this way,when the bleeder on one of my rear wheel cylinders snapped off when attempting to bleed the brakes after replacing a rotted steel line in sub zero temps!..I later drilled out and removed the busted bleeder at home,in my warm garage!..:crazy:
  13. goldwing2000
    goldwing2000 Guest
    I've done the same thing. Running my 14bff like that right now, in fact.
    Chris, Autozone sells the 6-pin wheel nut socket for $15 plus tax.
  14. Chrisblazzer89
    Oct 12, 2006
    1,966
    Massachusetts 02301
    I got it all done I got the 6 pins nut off bye useing a punch
  15. goldwing2000
    goldwing2000 Guest
    Getting them off that way is fine. You should use the socket and a torque wrench to put it all back together, though.
