brake drums...
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by StageZ, Jul 20, 2001.
  1. StageZ
    StageZ Registered Member
    Jul 2, 2001
    92
    Los angeles CA
    has anyone had a brake drum lock on... I cant get my back left drum off... any suggestions... the right one came off easy... but the left is stuck...
  2. slider79blazer
    slider79blazer 1/2 ton status
    Mar 23, 2001
    164
    littleton,co.
    you might have a lip on the drum from wear just back off the pads with a screwdriver through the plug hole in the drum. when tention is releived it should slide off.
    <font color=purple>whats a 4 letter word for farm wagon?</font color=purple> <font color=blue>ford</font color=blue> [​IMG]
    <a target="_blank" href=http://community.webshots.com/user/slider79blazer>http://community.webshots.com/user/slider79blazer</a>
  3. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    The other place that they can get stuck is the on the axle shaft. You will know that it is froze onto the axle because it will not move in and out at all where if it is the brakes there will be some play because of the hold down springs. Some penitrating oil and a hammer helps if they are froze on the axle.
    '71 Blazer CST w/ a 400sbc, 4" lift, 36" Supper Swampers, and alot of rust
  4. StageZ
    Jul 2, 2001
    92
    Los angeles CA
    thanks for the help guys... 1 hour of hammering did the trick... the brack shoes and the drums are all carved up....
