Brake Experts I have a question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Lazydog, Oct 5, 2002.
  1. Lazydog
    Lazydog 1/2 ton status
    Apr 17, 2002
    129
    Phoenix, Arizona
    I have a 1978 GMC Jimmy. My question concerns the proportioning valve. It looks like there is a 1 1/2 inch fitting between the valve and the brake line to the rear brakes. That fitting is leaking. It actually looks like there is a blowout valve on the side up against the frame. The dealer parts guy said these things do leak over time. Is that right? The new valve is $90.00 so I thought I'd get a second opinion before purchasing.
  2. dyeager535
    26,979
  3. 79Beast
    79Beast 1/2 ton status
    Dec 9, 2001
    1,155
    Georgia
    Sounds like a junkyard part is needed. I've never seen one leak before. I have one I'll sell you for $10 off of a 74 Blazer. Also, it's a splitter block...not a proportioning valve. It should be mounted on the crossmember in front of the engine.
