Brake flaring tool
Discussion in 'The Garage' started by 1HighK5, Dec 2, 2005.
  1. 1HighK5
    1HighK5 1/2 ton status
    Feb 7, 2005
    140
    New York
    Where can I get a good brake flaring tool to do my steel lines with. The one my buddy has is a real peice it is the worst so I wanna buy a good one. Where can i get one and what name or kind is a good one. Please help
  2. gmcman7202
    gmcman7202 1/2 ton status
    Sep 19, 2005
    181
    The land of FIBS
    other than the snapon one i have used, i have had good luck with the one i picked up at the local bumper to bumper for 25 bucks.... worked just like the snapon.... it was some generic brand, but better than the one at harbor freight
  3. sweetk30
    Nov 1, 2004
    25,547
    542
    horseheads , ny 14845
    how much you want to spend? i have a sweet unit that does 5 american 4 metric bubble 3 push conect fuel and 2 oring fuel/power steering lines. it is hand held hydrolic. pump the lever with your thumb. easy to use and works great. cost is pricy $$$
  4. 1HighK5
    Feb 7, 2005
    140
    New York
    I don't think i need all that just somthing better then the worn out junk my buddy lent me
  5. wforicv
    wforicv 1/2 ton status
    Feb 16, 2004
    165
    Back in Augusta, GA again
    I bought the Harbor Freight junk. It is not very impressive, but it did a good job on my 14BFF lines. I think I got it under $10.00. It may fall apart next time, but I got $10 off use out of it and no leaks.
    Eric
  6. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    Just a side note: the more square and burr-free that the end of the tube is, the beeter the flare will be.
  7. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    I bought mine from Napa for about $20. It works fine for the few times I use it.
  8. DieselDan
    DieselDan 1/2 ton status
    Jan 27, 2001
    1,056
    Vermont
    Get a flaring tool that uses hex head (instead of wing-nuts)to grip the tube and to press the flare. I've used a bunch of different versions and the one I bought at a local autoparts store works pretty good for the money. Brand name is "Pr" :confused:
  9. ck_1500
    ck_1500 Newbie
    Dec 1, 2005
    Pennsylvania
    Rigid makes a heavy duty double flaring tool. It's about $80.00, but it does a
    professional job. They are available from Grainger. I'm sure an industrial supply house can order you one also.
  10. spearchucker
    spearchucker 1/2 ton status
    Nov 17, 2003
    1,556
    Bay area, CA
    Rent one for free from Autozone.
