Brake fluid didnt go back to normal?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by JimmyJuneau, Sep 9, 2001.
  1. JimmyJuneau
    JimmyJuneau 1/2 ton status
    Apr 11, 2001
    811
    Juneau, Alaska
    Ok I just changed out the front disc brake pads last bnight on my 85 Jimmy. I did as the chiltons manual told me I used a c clamp to retract the cylinder that compresses the pads. After I did that I replaced the pads with new ones. And put everything back together. But this morning After I have pumped the brakes and everything and have driven the truck I open up the hood and it smells like something is brning and it looks like the fluid hasnt gone back to its normal level and is leaking through the top of the cover. What should I do?
    1985 GMC JIMMY
  2. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    It sounds like your piston in the caliper isn't sticking out as far because of the extra "meat" on the brake pads. In other words, the piston displaced extra brake fluid. I'd just stick a rag in the resovoir(that duzn't look rite), soak up some fluid, and put the cap back on.
    That jeep thing? Yah I understand it....... Like my Blazer? <a target="_blank" href=http://community.webshots.com/user/blazerk5>http://community.webshots.com/user/blazerk5</a>
    Jim
  3. '73 K5
    '73 K5 1/2 ton status
    1,763
    Kansas
    Maybe a little fluid squished out from the master cylinder and is burning on the exhaust. As long as the master cylinder didn't get completely dry and you didn't open the system, you won't need to bleed anything. Just fill it up to about a quarter inch from the the top and drive it...check it again in a few days.
    '73 K5
    Chevy good...Ford bad
  4. JimmyJuneau
    Apr 11, 2001
    811
    Juneau, Alaska
    thats the problem It is completely full is that normal?
    1985 GMC JIMMY
  5. SWAMPRNR
    SWAMPRNR 1/2 ton status
    Apr 7, 2001
    296
    Temple Texas
    Did you have the lid off when you pushed the brake pistons back in ? you should have, All that extra fluid that was in the caliper has to go somewhere.
    A BIG HAMMER CAN FIX ANYTHING.. [​IMG]
  6. TorkDSR
    TorkDSR 1/2 ton status
    Sep 1, 2001
    1,258
    bucks co pa
    does it stop right? well if it does don't worry, but make sure to keep checking fluid level, after all the extra comes out the lid it should stop, the bigger pads will cause extra fluid.
    PS watch out iv started many a fire under my hood, and brake fluid will catch fire on headers, just thought you'd feel safer knowing
    Tork DSR
    I just got a winch, it takes the fun out of things.
  7. '73 K5
    1,763
    Kansas
    jimmyjack sounds right to me...that is about the only thing that makes sense.
    '73 K5
