Brake fluid Smell?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by CaptCrunch, Aug 8, 2001.
  1. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    I have had a weird brake fluid smell that appears (or is smelt) occasionally since I have lifted my truck. Everything is working fine... no leaks or anything. Actually everything has been replace within the past year... calipers, wheel cylinders, master, etc. I do have Pro Comp Stainless steel brake lines, would that possibly be causing my woes? They aren't rubbing or anything and are tied off. The only thing I can think of is that the fluid is boiling, but why? No sticking calipers and the calipers feel cool, so I'm kinda stumped. Any ideas?
    -Mikey
    1987 Chevy K5 Blazer- 350 TBI
    <a target="_blank" href=http://www.geocities.com/milnerlives_2000/blazer.htm>http://www.geocities.com/milnerlives_2000/blazer.htm</a>
  2. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    I'd guess it's just a little escaping from the stainless lines - I've heard of this happening with them before.
    Dos mas Tecates!!!
    <a target="_blank" href=http://pugsley.alloffroad.com>pugsley.alloffroad.com</a>
  3. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    Keep an eye on the fluid level. Itt will give you an idication of how fast it's leaking (or if it's leaking)
    If you didn't build it yourself, how can you call it yours.......?
  4. CaptCrunch
    Feb 2, 2001
    3,596
    Minnesota
    No leaks... haven't added fluid in 2 months since I bleed out the brakes and prop valve.
    Man if this is just the brake lines who's got the NAPA numbers for extended rubber lines? LOL This smell is becoming one of the most hated smell from a car... just short of skanky coolant... eww. I also suppose our 99 degree temp's haven't helped... stupid misriable summer.
    -Mikey
