brake hard line size
Discussion in 'The Garage' started by dodgedude99, Oct 6, 2005.
  1. dodgedude99
    dodgedude99 1/2 ton status
    Jul 12, 2003
    784
    burbia of illinois
    i had ordered my flex lines from Xtreme Crawlers back in July and just finally getting to installing them on my project K5 (im a procrastinator).
    well the rear dropdown line was made with a fitting for 3/16"s fittings (even though i specified 1/4"), does anyone see a problem running a 3/16 line instead of a 1/4" line to the rear discs?
    or should i see if he will swap the end out for me?
  2. steve_kibbe
    steve_kibbe 1/2 ton status
    Feb 4, 2004
    2,895
    Spartanburg, SC
    I'd run 1/4, if thats what you asked for. 3/16 is 25% smaller line, I think that would make a difference. :o
  3. DieselDan
    DieselDan 1/2 ton status
    Jan 27, 2001
    1,056
    Vermont
    I think you'll find that most cars with 4whl disc are using 3/16" front and rear. I just replumbed mine with 3/16 all around. 'Haven't driven it much (just a test drive before I tore the engine down) but it felt and stopped great! :waytogo:
  4. sweetk30
    Nov 1, 2004
    25,539
    539
    horseheads , ny 14845
    1/4 feed from master then 3/16 to ends of axle is factory.
  5. dodgedude99
    Jul 12, 2003
    784
    burbia of illinois
    and i specified that the line all the way back would be 1/4", but i also told him that i have rear discs. so i dont know if he figured i wouldnt need a 1/4" capacity.
    doesnt one of them (disc or drum) require less volume or something like that?
  6. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    I would rather have a 3/16" line than a 1/4" line. You don't need a lot of volume for disc brakes.
  7. steve_kibbe
    Feb 4, 2004
    2,895
    Spartanburg, SC
    :dunno:
    I was just guessing :crazy:
  8. dodgedude99
    Jul 12, 2003
    784
    burbia of illinois
    cool thats what i was figuring that he was figuring.
    i just have to adapt the 3/16" to the 1/4" fitting on the prop valve now.
    thanks guys
    shawn
  9. divorced
    Jul 20, 2004
    5,115
    My local Napa has several size adapters to this. They even had one to go from a 9/16" thread to a 3/16" line for my old Ford. Good luck with it :thumb:
