Brake help: Front drivers side locking up **UPDATE**
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by seanp, Sep 8, 2003.
  1. seanp
    seanp Registered Member
    Sep 3, 2003
    68
    S.E. KS
    On my 83 Jimmy the front drivers side is locking up when braking. If i'm real easy on the brakes it won't completely lock up but you can feel it locking up and unlocking. When it does this the whole truck shudders. I thought i would try to diagnose the problem, but i took the wheel off and have no idea what to look for. Any ideas?
  2. Stoopalini
    Stoopalini 1/2 ton status
    Oct 17, 2000
    999
    Austin, Texas
    Re: Brake help: Front drivers side locking up
    How do the rotors and pads look .... Any grooves? Plenty of meat? Rivits showing?
    Sounds like the caliper might be sticking/locking up. You could just try cleaning the caliper up and greasing the guides, or it might need to be replaced.
    Thomas.
  3. seanp
    Sep 3, 2003
    68
    S.E. KS
    The pads and rotors look fine. I took the caliper off, but i don't see any place to grease it.
  4. Stoopalini
    Oct 17, 2000
    999
    Austin, Texas
    There are 2 long shafts with allen heads on the end that hold the caliper in place. As the pad wears, the caliper slides on those.
    Were they rusted at all, did everything come apart cleanly? If the pads and rotor look good, you might just want to replace the caliper if you can.
    Thomas.
  5. seanp
    Sep 3, 2003
    68
    S.E. KS
    The shafts came out pretty easily. I wonder how much a new caliper costs?
  6. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> New calipers are cheap, I think I got some for like $12 each a couple years ago. </font>
  7. seanp
    Sep 3, 2003
    68
    S.E. KS
    I just got one, $18 from Napa.
  8. seanp
    Sep 3, 2003
    68
    S.E. KS
    I put on new calipers and brake pads on the front. And for 5 days the brakes worked perfect, but now it's starting to do the same thing as before. Somebody said a brake line could be bad causing the caliper to stick. How would i know if it was the hard line or the rubber line that was bad?
  9. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    First, puell the front brakes apart on both sides and use this stuff called Sul-Glyde (Napa sells it for likr $4.50) and get a hardware kit for the calipers that will include the slide pins and new rubber o-rings and the slider bushing...INsall the new hardware and lube well with the Syl-Glyde...Then give it a try...what does your fluid look like? There could be lots of crap floating around causing the caliper to NOT release when you let off the pedal. But I would first ensure that the caliper is floating freely as it should and not getting hung up on old orings and rusty guide pins, then maybe have the system FLUSHED if the fluid is questionable. It is usually the rubber lines that deteriorate with time and start contaminating the fluid and preventing pressure release...
    Chris
  10. seanp
    Sep 3, 2003
    68
    S.E. KS
    The calipers came with new bushings and seals. i also cleaned up and greased the slider pins before i reinstalled them. I guess i'll have to get new brake lines now.
  11. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    if a rubber hose deteriorates from the inside out, it can cause a flap to occur inside the line that the fluid wont release pressure when you let off the brakes...if the hoses are original...why not replace them as preventative maintenance? cheap assurance..
  12. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    While you're at it, do a search and get the super long ones that people have found to fit.
  13. fortcollinsram
    Nov 8, 2001
    2,261
    Fort Collins, CO
    aight, time for new rubber lines and a brake system flush... /forums/images/graemlins/thumb.gif
