Brake help on 1st gen, with dana 60 front
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by TheBlazerKid, Feb 4, 2001.
  1. TheBlazerKid
    TheBlazerKid 1/2 ton status
    Apr 26, 2000
    259
    Raymond, Washington
    Ok guys i need help with this one, I got my 14 bolt and dana 60 front axle all finished today got teh brakes bled and everythign hooked up right, so I go for a test drive and THERES NO [censored] BRAKES, I dont know what the hell is wrong with it I have bled it like 4 times, the petal just squishes down to teh floor and teh light comes on, HELP!
    Theres No Replacement for Cubic Inches!
  2. tRustyK5
    Jul 23, 2000
    36,178
    1,387
    E-town baby!
    Did your master cylinder get empty? If so it may need to be bench bled. Another possibility is that the repeated pumping of the pedal down to the end of the master cylinders stroke wiped out the seals there. When the pedal is pumped for bleeding the brakes it shouldn't be allowed to go to the floor. A piece of wood under the brake pedal helps for this. My guess is that the master cylinder is toast.
    Rene
  3. TheBlazerKid
    Apr 26, 2000
    259
    Raymond, Washington
    that i didnt know, i just put a brand new master cylender on it, cause teh sael was bad on the old one, we bench bled it first, then we used the push the pedal method, then we used a pressure bleeder, then the foot method again, thats a thought ough thanx
  4. tRustyK5
    Jul 23, 2000
    36,178
    1,387
    E-town baby!
    I wiped one out that way, found out from the parts guy when I brought it back [​IMG]
    Rene
  5. 72blazer4x4
    72blazer4x4 Registered Member
    Jan 27, 2001
    60
    vacaville ca
    im having the same problem right now with my dana 44. i have a master cylinder no more than 4 months old in it. my dad and i found something that could fix it and were gonna try it tomorrow and if it works ill tell ya.
    jeremy
  6. thatK30guy
    Jan 12, 2001
    32,076
    55
    Are you running a vacuum booster? Since you installed a D60, you may not have enough pressure to pump the bigger brakes. If this is the problem, look into getting an adjustable proportioning valve. Another possibility to look into is to change over to hydro boost system like whats on diesel and one ton trucks.
  7. TheBlazerKid
    Apr 26, 2000
    259
    Raymond, Washington
    yeah I have a vacuume booster, I thought of that one also, I bought the whole truck that i got teh axles from and the hydro boost system is still on there so if worst comes to wrst i coudl change it, but that would be a pain in the ass as its backwards from my 71's lines, but maybe
