Brake? HELP QUICK
Discussion in 'The Garage' started by chevyfumes, Jun 24, 2002.
  1. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
    I was extendidg the piston on the caliper to clean it cause it was sticking and I think it came out too far because the rubber seal started leaking fluid and when I compressed the piston back it looks like the rubber is bulging out a little in one spot... am I screwed or what?
  2. muddysub
    Jun 23, 2001
    10,451
    489
    my garage, Henderson, NV
    honestly i would get scared and replace the caliper. /forums/images/icons/frown.gif
  3. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    Yup /forums/images/icons/cool.gif
    Actually I have no idea, I don't do brakes..........sorry. Just wanted to make ya smile /forums/images/icons/smile.gif
  4. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> Yeah, I'm pretty sure you're screwed. I've always heard that if you overextend the piston then you have to get a new caliper. </font color>
  5. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    Your only screwed if you're broke. A new caliper is only about $15 /forums/images/icons/cool.gif
  6. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Dude...just put it back to gether. You are only screwed because you let air in and now have to bleed them. You also could be screwed if you tore any of the seals.
  7. chevyfumes
    Feb 24, 2000
    38,584
    266
    Thats what I though I don't think I ripped it I'm gonna tear it down right now thanks.....
  8. trailblazer87
    trailblazer87 1/2 ton status
    Jun 11, 2002
    707
    Madera, CA
    Worst case is that you tore one of the seals and need to rebuild the thing. It is about as easy as it gets. Sounds like you pinched the seal a little and just need to replace it, about half an hour of work, and help pumping the pedal to bleed them.
  9. chevyfumes
    Feb 24, 2000
    38,584
    266
    I tore the thing apart and I only pulled the boot loose so I was able to put it back together, Thanks guy's, and after cleaning both calipers the stupid truck still pulls to the right when braking any ideas on this matter..... /forums/images/icons/crazy.gif /forums/images/icons/grin.gif
  10. trailblazer87
    Jun 11, 2002
    707
    Madera, CA
    What color is the fluid in the system? If it is brownish then there is water present and it will do strange things, if it is clear then it sounds like it might be your proportioning valve. Also make sure your wheels bearings are properly tightened and not over done and that the pads are wearing evenly. If not then you may be dragging one a little.
  11. chevyfumes
    Feb 24, 2000
    38,584
    266
    Fluid is light brown , pads are new, wheel bearings should be fine I replaced them about a year ago and this just started a few months ago,and as for them sticking, thats why I over extended the piston in the first place was too clean them. I started out cleaning the right side even though it pulled to the right and it actually helped quite abit but still pulled pretty hard so I did the left side and it is almost gone but still pulling to the right, could it be my rear drums I replaced the drums and shoes about 7 months ago and never cleaned anything the way I should have, but like I said this problem just started, any other help or thoughts are appreciated..... /forums/images/icons/cool.gif
  12. trailblazer87
    Jun 11, 2002
    707
    Madera, CA
    Have someone mash the pedal while you look for leaks on the left side. Is it pulling the steering wheel? If so it is in front, you get the picture. It is a good idea to pack the bearings anually, be sure to get all the old grease out. If it is the back then you could be dragging a shoe, inspect the pads at all corners for spidering (hairline fractures), if any show in one corner then you are over heating that pad and the cracking will show up. I hate brake problems, they are always the hardest to diagnose /forums/images/icons/confused.gif
  13. chevyfumes
    Feb 24, 2000
    38,584
    266
    Thanks.... /forums/images/icons/wink.gif
  14. tomseviltwin
    tomseviltwin 1/2 ton status
    Dec 23, 2001
    2,065
    Utah
    Alignment prob? Any bad treadwear?
  15. chevyfumes
    Feb 24, 2000
    38,584
    266
    It started before I put the lift on and everything seems to be fine in that respect and it also has new shoes that were rotated when I did my lift... any more issues on fluid color or proprtioning valve from you guy's or anything else for that matter... /forums/images/icons/wink.gif
  16. COOTER
    COOTER Registered Member
    Sep 25, 2001
    49
    SOUTH EAST GEORGIA
    How bout proportioning valve?
  17. uglychevyZZ4
    uglychevyZZ4 3/4 ton status
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    i didnt bother reading all the posts, but for all you who dont know the answer, Rob, the boot is just that, a dust boot, but what is leaking is a torn or dislocated O-RING at the back of the piston, just go get a o-ring kit for 1.00 at the parts store. or ill mail ya one! /forums/images/icons/wink.gif
  18. FLASHLIGHT76
    FLASHLIGHT76 1/2 ton status
    Jun 20, 2002
    255
    OREGON
    I have the same problem and I found out that my right side ball joints on the axle and tie rod which don't affect me in motion but when I touch the brakes she pulls to the right. I Just rebuilt both callipers for 10 bucks and now it's only a little pull. I would check ball joints on the knuckle just for good measure.
