Brake help
Discussion in 'The Garage' started by trailblazer87, Jul 15, 2002.
  1. trailblazer87
    trailblazer87 1/2 ton status
    Jun 11, 2002
    707
    Madera, CA
    I have just replace my master cylinder, and the steel hardline for my front brakes and it still won't stop. I bled them till no air came out and the fluid ran clean. This is the same thing it did before I replaced everything.
    Any help would appreciated.
  2. Mreetz
    Mreetz 1/2 ton status
    Jun 26, 2001
    1,282
    Subs of Denver, Colorado
    When you bled them did you start with the one farthest from the master cylinder? /forums/images/icons/confused.gif
  3. trailblazer87
    Jun 11, 2002
    707
    Madera, CA
    Yep, my buddy is telling me to reverse bleed them, never heard of this before. Yeah, bled them passenger rear first, then driver rear, then pass. front, the driver front. Tried to bleed a little more tonight, and the driver front blows fluid, then a little puff of air, then more fluid. The air always happens when the pedal gets halfway down, not sure what this means. But they also won't pump up pressure when you pump them a bunch. the pedal is real lazy about coming back up from compression.
  4. k5blazerus
    k5blazerus 1/2 ton status
    Apr 22, 2001
    654
    Bend, OR
    Did you adjust your rear brakes. Do that and you will notice a big inmprovement. Best way to adjust them is by jacking up the rear and tacking out the plugs on the backing plate. Behind that is a star adjuster. Take a flat head and adjust them till the tire will only spin 1 and a 1/2 rotation. Then bleed them from the RR tire, LR tire, RF tire and then LF tire then the master cylinder. Also check your rear wheel cylinders to see if they are leaking.
    If you have any more questions cantact me.
    colin
    Colin
