brake help
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by MUDNUTT, Sep 16, 2003.
  1. MUDNUTT
    MUDNUTT 1/2 ton status
    Aug 1, 2001
    339
    Mn
    hey all, i installed a hydro boost system out of an 82 diesel pickup into my k5 about a year, year and a half ago and the system has worked flawlessly until recently. couple of weeks ago it started pushing fluid out past the cover on the master cylinder. primarily coming out of the large front chamber. anyone have any ideas? im at a loss.
    deck /forums/images/graemlins/usaflag.gif /forums/images/graemlins/k5.gif
  2. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    hmm thats crazy, would there be any way that p/s fluid could travle from hydro unit into the m/c somehow maybe ?
    hmm..
    i hope you find out why its doing that, im curious,.
  3. MUDNUTT
    Aug 1, 2001
    339
    Mn
    i dont think so. the m/c bolts to the hydro unit like it would to a vacuum unit. last time i checked my p/s fluid it was full. i guess anything is possible tho.
  4. mudjunkie 82
    mudjunkie 82 1 ton status GMOTM Winner
    Dec 27, 2002
    11,449
    Cleveland Ohio
    Check out this website- jiml's brake paper. There is a ton of info here on hydroboost.
  5. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    if its brake fluid...the master cylinder is likely bad and bypassing the inner seal..
  6. MUDNUTT
    Aug 1, 2001
    339
    Mn
    thanks for the site. lot of info there but i couldnt find anything relating to my problem.
  7. MUDNUTT
    Aug 1, 2001
    339
    Mn
    not sure i follow you about the inner seal. its not leaking between the m/c and the booster. its leaking right out past the cap!
  8. MUDNUTT
    Aug 1, 2001
    339
    Mn
  9. Grim-Reaper
    7,385
    Atlanta
    Fluid from the rear resivior is getting past a seal internally in the MC and being pumped into the front resivior. The fix would be a new master or rebuild what you have.
  10. MUDNUTT
    Aug 1, 2001
    339
    Mn
    the rear resivior is never low. only the front.
  11. Confedneck
    Nov 1, 2002
    5,236
    sounds like a master cylinder internal bypass, get a new one..
  12. MUDNUTT
    Aug 1, 2001
    339
    Mn
    i'll look into a new m/c but that project just got put on the backburner for awhile. had a lobe go flat on my cam. anyone know the lift specs for stock vortec heads? i cant remember if its .465 or .475 max lift.
