brake hose position on the caliper
Discussion in 'The Garage' started by misfit, Mar 23, 2003.
  1. misfit
    misfit 1/2 ton status
    Jul 21, 2000
    324
    south central wa state
    my new calipers and hoses (1/2 ton fronts from a 74) will not stop leaking. what position should the hose be in, ive seen more than one. the "ears" on the hose appear to be sitting on a rim cast into the caliper. can i grind away excess material?
  2. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    My stock hoses pointed straight up. The new 38872's I run point back. This is front calipers.
  3. Highlander
    Highlander 1/2 ton status
    Nov 25, 2000
    1,204
    Lakewood Colo
    you did use the copper washers on both side right?
  4. MudNurI
    MudNurI 1/2 ton status
    Jul 15, 2001
    2,113
    VT
    If you didnt get new ones- make sure you do....there not suppose to be "reused".....
    Brandy
  5. Okiemuddog
    Okiemuddog 1/2 ton status
    Mar 3, 2003
    1,260
    Guthrie, Oklahoma
    make sure you put the copper crushwashers in. I had a moment of stupidity when I put my new lines on and the leaked like you know what. You can get them at any of your local parts stores. As to the placement, my procomp braided lines sit against the ears too, the crushwashers seal them up. The order is banjo bolt,crushwasher,line,crushwasher. Hope that helps. /forums/images/graemlins/thumb.gif
  6. thatK30guy
    Jan 12, 2001
    32,076
    55
    FYI: These are called "crush washers", so your parts man will understand a little better when you try explaining to him. /forums/images/graemlins/thumb.gif
  7. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    I have had problems with that too.
    There are 2 calipers # for each side of my k5. One has a round "spot faced" area around the banjo bolt hole and the "ears" on the stock brake line would not let it make contact and seal with the caliper. The other type had a "ridge" that went from the top to the bottom of the caliper and had a section of it cut out for one of the "ears" on the brake line to go.
    The calipers with the "ridge" are less common and they had to be ordered in at my pep girls.
