brake hose question
Discussion in 'The Garage' started by big dan, Aug 29, 2005.
  1. big dan
    big dan 1/2 ton status Premium Member
    Aug 1, 2005
    2,656
    29
    Arkansas
    i will be replacing brake lines on my truck this weekend and found some extended brake hoses on ebay (thanks to ck5) and thought i would go ahead and do that too. i want the ones that are 9inches longer than stock but the only ones i can find are for an 87-91 blazer or suburban. would these fit my 84 1/2ton pickup?
    thanks
  2. scrappy88
    scrappy88 1/2 ton status
    Mar 14, 2003
    314
    Loveland, CO
    Yes they should fit but where it attaches to the frame is different. The 87-91's use a clip to hold the line to the frame, and the 79-86 uses a nut. You could probably make it work just by getting some clips instead.
  3. big dan
    Aug 1, 2005
    2,656
    29
    Arkansas
    where might i find some clips and is it very hard to install them?
