Brake Issues Help Asap
Discussion in 'The Garage' started by ProJunkRacing, Jun 17, 2006.
  1. ProJunkRacing
    ProJunkRacing 1/2 ton status
    Jun 20, 2005
    1,229
    FrankFort IL
    Ok 1 Ton Axles Rear Disk 3/4 ton axles ok , I replace every line Except The Two From the master cyl .
    I Power Bled The Entire System , And I can build pressure and I have no pedal at all . Today had it out at at the mud bog and lost all pedal . S o Power Bled it then regualr bled it . It is weird On the left side front bleeder it will spray fluid from the bleeder literally to the back of the cab of the truck where it sits. I just can not figure out why it does this on the left side only and does not build pressure. the left rear does the sam shoots up a foot then bounces off the tire and goes another foot. but the left side barely get more than it should . Wtf do i do . They have a big bog that i need to conquer tommrow and with no brakes it ain t happening so i really need help . any ideas projunkracing is my aim just i really need help and none of my friends can figure this out .
  2. ProJunkRacing
    Jun 20, 2005
    1,229
    FrankFort IL
  3. mike n
    mike n 1/2 ton status
    Oct 9, 2003
    101
    New York
    Try another master cylinder.
  4. ProJunkRacing
    Jun 20, 2005
    1,229
    FrankFort IL
    other ideas?
  5. nemesis_pyros
    nemesis_pyros 1/2 ton status
    Mar 24, 2004
    229
    Winnipeg, Manitoba
    I don't know hom much this helps you but I had a very simular problem on a drum/drum setup. It turned out he auto adjuster wasn't auto adjusting on one side. As soon as I manualy adjusted it all the breaks worked great.
    And I just reread that you have rear disks:doah:
    well I hope somebody else has something usefull.
  6. ProJunkRacing
    Jun 20, 2005
    1,229
    FrankFort IL
    yes i do lol thanks for the help if none of my buddys come over forget it no desire to wrench alone
  7. ProJunkRacing
    Jun 20, 2005
    1,229
    FrankFort IL
    so it looks as tho there is brake fluid between the master and booster so master cyl
