Brake Light - ABS Check
Discussion in 'The Garage' started by TripleJ75, Dec 31, 2006.
  1. TripleJ75
    TripleJ75 Registered Member
    Nov 26, 2006
    38
    Connecticut
    Hi - just bought a 90 GMC Jimmy...brake light just came on..I checked the fluid and it's fine...I figure it's the ABS..how do you check the ABS Module?
  2. dremu
    Feb 27, 2000
    15,967
    458
    East of San Francisco
    ABS module will blink the light, not leave it solid.
    Brake light comes on with one of two things:
    There is or was a fluid pressure difference between front and rear. Push the reset button on the combination valve (on the crossmember, usually under a rubber nib). Yes, checking fluid level is important, but so is checking the calipers, hoses, and wheel cylinders for leakage. And while you're in the back, clean and check the adjusters. They need it.
    The parking brake lever is down, or is perceived to be down. Check wiring and the switch.
    -- A
  3. TripleJ75
    Nov 26, 2006
    38
    Connecticut
    Thanks..I'll check it out tomorrow!
