brake light acting up
Discussion in 'The Garage' started by jamber2541, Jul 27, 2006.
  1. jamber2541
    jamber2541 1/2 ton status
    Apr 10, 2006
    424
    e.p. texas
    Today on my way home from work my brake light came on the wierd thing is that it then started blinking quickly four times and then it pauses and it does it again and again??? anyone else have this problem before.:confused:
  2. Disciples Performance
    Disciples Performance 1/2 ton status
    Dec 6, 2005
    404
    Kelowna BC, Canada
    have u checked the brake fluid level yet i know of some vehicles the sensor in the brake system will flash a light if its running low just to warn you before you have no brakes so just check and top it up if needed and if its not that could be a relay or something grounding off sounds like making that light blink away
  3. dyeager535
    26,979
    I'm guessing you've got ABS, and thats an ABS code?
  4. dremu
    Feb 27, 2000
    15,958
    452
    East of San Francisco
    That there be a 1990-1991 truck with rear wheel ABS, yes.
    There are two or three different makes of brake computers, Kelsey Hayes and ... something else. Post up any markings you see on the computer -- it's the black box by the brake booster.
    Also, disconnect the battery(ies), wait fifteen minutes and reconnect them... this will reset the black box. (You could also disconnect it, but it's got multiple plugs and is a pain.) I find that the RWABS is mildly b!tchy and does this sometimes ... it's a pretty lame ABS, as they go, and on my truck that had I ended up just disabling it rather than dink with it.
    -- A
