Brake Light gremlin driving me crazy!!
Discussion in 'The Garage' started by Derf00, Dec 6, 2005.
  1. Derf00
    Derf00 1/2 ton status
    Jul 25, 2000
    1,683
    Abilene, TX
    If I don't solve this problem soon, I am going to take a BFH and beat the s*** out of something.
    From time to time my left brake light will quit working. If I use the use the left turn signal, the brake light will go back to working. When the brake light fails, the turn signal and the emergency lts continue to work. I suspect the problem is in the turn signal switch, but even though the switch has been replaced, the problem continues.
    Any suggestions??
  2. 83suburbman
    83suburbman Registered Member
    Oct 4, 2005
    13
    Vancouver WA
    Sorry no suggestions because mine do'es the same thing exactly!
  3. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    There is a loose ground at that taillight. Exact same thing happened to a buddy.
  4. daleearnhardt01
    daleearnhardt01 1/2 ton status
    Aug 29, 2002
    3,223
    Richmond, VA
    Yup same thing happened to me, redid all the grounds and all was well...
  5. muddyblzr
    muddyblzr 1/2 ton status
    Nov 2, 2004
    623
    houston/san antonio texas
    ahhh finally im having the exact same problem. now i just gotta find the sucker
  6. hack500
    hack500 1/2 ton status
    Sep 16, 2005
    523
    Templeton, Ma
    I had a bad bulb and my truck did that.
  7. Roz
    Roz 1/2 ton status
    Mar 27, 2005
    900
    San Diego
    could be bulb going out, ground or just dirty/corroded connections
  8. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    look at the ground prong in the socket for that light. I'll bet it si broken off at the bend.
  9. Leper
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    IIRC there is a ground wire in that area that comes loose/gets corroded.
  10. 90blzr
    90blzr 1/2 ton status
    Mar 25, 2001
    3,027
    SO CAL
    not sure if anyone else has mentioned this yet:D :wink1: .......
    but I may be a bad ground:eek1:
  11. Robert D
    Robert D 1/2 ton status
    Oct 2, 2005
    261
    Austin, TX
    I'm going to have to check this also, my brake light does the same thing.
  12. jims505
    jims505 Registered Member
    Apr 14, 2004
    19
    SO CAL
    If all else fails change your flasher unit.
