brake light on dash
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by CenTxk5blazer, Aug 6, 2003.
  1. CenTxk5blazer
    CenTxk5blazer Registered Member
    Oct 19, 2002
    90
    Fort Worth, Texas
    It came on a few days ago, on my dad's 91 2wd 1500, the truck does have anti lock brakes ( don't know if its rear or all four). The switch doesn't seem to be sticking and I don't think the pedal feel has change. It does have a good amount of fluid in the master cylinder. Does anyone have any idea of what could be causing it to stay on?
  2. flyndragons
    flyndragons Registered Member
    May 28, 2002
    18
    Finally back in the US!
    It could be the ROWL or RAWL unit. It is a computer box under the hood. That was happening to a friend of mine and when they replaced the unit it was fine again. There was a dent in the casing causing it to ground out. May be the prob. But I'd have to see it to be sure.
  3. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    there were tons of problems with the new ABS systems those years, im not surprised at all one tiny bit even, i avoid all ABS GM vehicles especially the first years' ABS ones. GM also had the problems with the new 700r4 in 82-86, seems like anything new they start putting out there has problems for years and years, replacing that ABS unit wont be cheap, i would sell or trade off asap if it were mine
    good luck
