Brake light prob........
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 4x4blazer, Apr 7, 2002.
  1. 4x4blazer
    4x4blazer 1/2 ton status
    Jun 14, 2000
    278
    Louisiana
    Left rear brake light went out. Tail light works with headlight switch. But no brake light. Replaced bulb.......no worky. Replaced bulb again......no worky. Looked for broke wire.....no broke wire. Any ideas???????
  2. Michael
    Michael 1/2 ton status
    1,576
    Sherman, Texas
    Check the socket for corrosion or loose connection. Check the wiring under truck. Yellow is for left side stop/blinker. Brown is for Taillights, Dark Green for Right stop/blinker. If the wiring is good work your way up to the signal light switch under the steering wheel.
  3. 89Blazin
    89Blazin 1/2 ton status
    Mar 20, 2001
    134
    midwest KC area
    Does the turn signal work? This can help isolate the problem.
