Brake light problem
Discussion in 'The Garage' started by dheavychevy38, Feb 15, 2005.
  1. dheavychevy38
    dheavychevy38 1/2 ton status Premium Member
    Jan 6, 2003
    1,003
    Algonquin,illinois
    Ok my right rear turn signal and brake light don't work and yes i already checked the bulb and to see if there is power back there and the answer is no. It is on a 89 k5 any ideas or does anyone have a wireing diagram thanks.
  2. dwoods
    dwoods 1/2 ton status Premium Member
    Jan 26, 2005
    304
    DuBois PA
    This my help
    I made a new harness from this diagram and it work like new. Iam fairly sure your K-5 blazer is the same as my 87 V-20.
  3. dheavychevy38
    Jan 6, 2003
    1,003
    Algonquin,illinois
    i checked i have no power right after the fire wall so it must be in the cab part.
  4. frankin5
    frankin5 Super Mall Crawler Premium Member
    Oct 15, 2002
    883
    114
    chico,calif
    most likely the turn singal switch in the column
