Brake Light Q's
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by jimmyjack, Mar 16, 2002.
  1. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    Brake Light Q\'s
    Ok, heres the deal. My brake light comes on intermittently. The fluid level is good. The pads and shoes are both basically brand new. Doesnt have a problem stopping, doesnt pull. Is it a glitch or am I missing something completely?
  2. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    Re: Brake Light Q\'s
    I hade an issue similiar to this on my '76. I guess the light "moniters" brake system pressure and comes on if something isnt right. (someone correct me if I'm wrong) I replaced the wheel cylinders and the light went off. Don't know if this could be your prob or if ya just have one of those wierd wiring gremlins.
  3. RESTORE89
    RESTORE89 1/2 ton status
    Jan 31, 2001
    548
    CHAS SC
    i think your on the right track. you are getting uneven pressure somehow. did you open any lines durring brake replacement. try bleeding the lines.
  4. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    It is some type of fluid leak. I would guess in the rear because the front normally causes a noticable pull. Check the wheel cylinders in the rear. You have to pull back the dust boot to see if the seal is leaking.
  5. jimmyjack
    May 11, 2000
    2,290
    Tucson Az
    I never messed with the calipers or pistons or cylinders when I replaced the brakes but I will look into that. Havent noticed the resevoir looking like it was low but I'll keep an eye on that too. Thanks for the input guys!
