brake light relay question
Discussion in 'The Garage' started by BranndonC, Sep 21, 2005.
  1. BranndonC
    BranndonC 3/4 ton status
    Mar 18, 2002
    8,591
    Anaheim, Ca
    how would i go about getting my brakes to go "Flash, flash, solid" when i hit the brakes, like 2 flashes with in a second or less, then stay solid from then on. I have led bulbs if that matters
  2. Russell
    Russell LB7 Tahoe Status Premium Member GMOTM Winner
    Jun 23, 2000
    7,922
    333
    Fort McMurray, Alberta
    Not quite sure I understand the point of the flashing, but I am pretty sure you'd need to build some sort of a little electronic controller...
  3. wildbilzrydn
    wildbilzrydn 1/2 ton status
    Jun 27, 2005
    118
    Joliet, IL
    Can you program PLC's? Know anyone who can? I do a little industrial control stuff, like relays and such and the only way I can see to do that is with a PLC. Plus, you'd have lots of adjustment.(you could scroll your lights around the truck or have them flash like a ambulance too.) Either that or you'd need two time delay relays, set at different times..... I'd say that would work too with a little head scratching
  4. BranndonC
    Mar 18, 2002
    8,591
    Anaheim, Ca
    i dont know anything about electronics really, i know its somewhat possible though because my friend has 3 brake lights come on one after the other when he hits his brakes.
  5. Russell
    Jun 23, 2000
    7,922
    333
    I'll do a little research and see if thats something I can set up using a 555 timer or something.
    Gimme a day or two :)
  6. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    Was thinking that's a timer deal too. Could possibly do it with an oscillator circuit, but I've not a clue how to go about that. Using a PLC would be like hitting a forming nail with a gold plated hammer. It'd work, but jeez....
  7. wildbilzrydn
    Jun 27, 2005
    118
    Joliet, IL
    Yea, but just think about the possibilities, Infinite control, he could flash them 100 times, or have random or whatever. used PLCs can be had fairly cheap.....
    Learning laddder logic wouldn't be bad either.
  8. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
  9. BranndonC
    Mar 18, 2002
    8,591
    Anaheim, Ca
    this is what i see when i look at that
    But if thats what i need to do, maybe i could find someone who understands that to help me. thanks :bow:
  10. TJS
    TJS 1/2 ton status
    Nov 13, 2001
    179
    Westport,CT
  11. BranndonC
    Mar 18, 2002
    8,591
    Anaheim, Ca
    cool, i'm on the right track now, i'm searching the net to find one for my application
  12. Russell
    Jun 23, 2000
    7,922
    333
    I'm working on a custom chip for ya, to see if I can come up with something that is built to your specs.
    Basically, I need to know exactly how you want the lights to behave, then I'll send you the diagram, along with a parts list. Pretty easy to follow the wiring, and easy to do too, you can get all the parts you need at Radio Shack (or is it called The Source by Circuit City down there too?)
  13. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    the diodes going to the brake light would prevent any current from reaching the lights,
    they are in backwards :D
