brake light/ turn signal
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by alexlong, Mar 3, 2004.
  1. alexlong
    alexlong Registered Member
    Feb 29, 2004
    10
    College Station, TX
    My driver side rear taillight/ turn signal is out, and it's not the bulb or wiring, everything looks connected all the way up. Any ideas? I need to get inspected (expired since August!)
  2. Tweetysuarus
    Tweetysuarus 1/2 ton status
    May 25, 2002
    2,294
    Lynnhood,WA
    Did you check it with a volt meter? What was the last mod or repair you did?
    Bill
  3. Derf00
    Derf00 1/2 ton status
    Jul 25, 2000
    1,683
    Abilene, TX
    Does the turn signal switch function properly? The turn signal switch in the steering can cause both not to function properly.
  4. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    You could have a bad gound most probably, or the switch.
    Fisrt take off the lenses and take off the screw holding the ground and clean the metal there and the reinstall.
    If that doesn;t cure it then check the switch.
