Brake Lights and Turn Signals
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by senatorwoodhouse, Jun 21, 2005.
  1. senatorwoodhouse
    senatorwoodhouse 1/2 ton status
    Jan 22, 2005
    108
    des moines, IA 50311
    So I knew that my turn signals didn't work, but one of my friends was backing my 81 k5 out of the driveway the today and I noticed that I have no brake lights. :crazy: I have had this problem with older k5's that the button thta is actuated by the pedal gets pushed over. But upon searching for this easy fix I was dissapointed to find no such luck. Are the brake lights operated by a pressure switch? If so where would this unit be located? Anyone else had problems like these?
  2. senatorwoodhouse
    Jan 22, 2005
    108
    Oh yeah I also might want to put in the obvious...the bulbs are ok
  3. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    The switch on the pedal is the only switch. Might want to check your ground at the back end behind the housing.
  4. wicked87_k5
    wicked87_k5 1/2 ton status
    Aug 9, 2004
    235
    Little Falls,NJ... North
    I had the same problem on both of my K5's 77 & 87 . turned out to be melted wires, drivers side frame rail between the rear tire and the bumper.
  5. senatorwoodhouse
    Jan 22, 2005
    108
    Just the stupid button got pushed back away from the pedal. That stupid thing is waaaaaaaaay up the pedal. what a pain to bend back. :cool1: Thanks for the help everybody.
