Brake Lights Staying On, HELP PLEASE!
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by K5Willie, Jul 9, 2002.
  1. K5Willie
    K5Willie Registered Member
    Nov 26, 2001
    5
    VA
    Here's the deal, I was driving my 72 home the other night and the brakes went out at a busy interection! Bout [censored] my pants but managed to cruise up onto the nice lawn of a Texas steakhouse and roll to a stop (they didn't like my tires). Anyway, I get up under the dash and the linkage between the pedal and master cylinder had come apart. So I put it back together and now my brake lights stay on constantly. This didn't happen before and I can't seem to find a switch anywhere under the dash. Anybody else had this problem? HELP please!
  2. chulisohombre
    chulisohombre 1/2 ton status
    Apr 11, 2002
    4,141
    14
    Bangor,Pa
    the switch is up on top of where the brake pedal mounts.you might be able to adjust it so the lights will turn off
  3. skyblazer
    skyblazer 1/2 ton status
    Oct 1, 2000
    209
    Houston, TX
    It's a white plastic switch that is treaded into the brake pedal assembly...It can be adjusted by loosening the stop nut on the treads and threading the switch in or out to adjust where the switch opens.
  4. K5Willie
    Nov 26, 2001
    5
    VA
    thanks guys,
    I found the switch. I feel like an idiot. (guess I'm just used to *gasp* Fords!) Anyway, I adjusted the pedal and end of problem. Now if I could only get that O-ring around my tranny dipstick to stop leaking!!
  5. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    if its not out of adjustment its because you developed a leak somewhere. probably just the pedal thoug.
    nathan
