Brake Lights
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Chaz316, Aug 2, 2001.
  1. Chaz316
    Chaz316 1/2 ton status
    Jul 25, 2001
    224
    Georgia
    I am having a problem with the brake lights on my 73. I've checked the fuses and bulbs and all seem to be good(replaced fuses and bulbs for good measure). The running lights and blinkers work fine. Any ideas?
    73 K5, 350, auto w/factory air, 4in susp, 35's
  2. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    trace the wires i bet you have a short somewhere or the little switch under the breakpeddle is bad
    77blazer see it at<a target="_blank" href=http://community.webshots.com/user/ssmith6333>http://community.webshots.com/user/ssmith6333</a>
  3. Eagle86K5
    Eagle86K5 1/2 ton status
    Mar 5, 2000
    974
    Whitehouse, Ohio
    What is the problem?
  4. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    his turn signals work and running lights work but no brake lights
  5. kpanza
    kpanza 1/2 ton status
    Dec 8, 2000
    1,579
    Lake Forest, Orange County, California
    My brother's F*rd does this also, anyone know what the problem is? I told him to try changing the bulb. It's just when he touches the brake, his left rear taillight goes out...
  6. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    the guy with the ford i would say definatly has a short some where i would trace the wires from the fusebox back to the tail light that keeps going out
  7. Chaz316
    Jul 25, 2001
    224
    Georgia
    I was reading about an adjustment for the switch under the pedal and I never thought to check to see if it was actually even touching.
  8. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    You probably have a broken wire somewhere if the fuse is good... Get a test light and strat seeing where you have power to... these trucks love to get broken wires under the back bumper area and where they go on top of the gas tank. I have to totally rewire mine cause I keep losing the driver's side break light
    -Mikey
    1987 Chevy K5 Blazer- 350 TBI
    <a target="_blank" href=http://www.geocities.com/milnerlives_2000/blazer.htm>http://www.geocities.com/milnerlives_2000/blazer.htm</a>
