Brake Lights
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by conv76jimmy, Dec 23, 2001.
  1. conv76jimmy
    conv76jimmy 1/2 ton status
    Feb 18, 2000
    281
    Yay Area, CA
    I have a 1981 Chevy Blazer that the Brake Lights aren't working, I just bought some new ones and they still don't work. The weird thing is that the Parking & Turn Signal ligts work just not the Brake Lights Any idea's!!!
    2-wheel'n all the way!!!
  2. 95 Silverado
    95 Silverado 1/2 ton status
    Nov 9, 2001
    467
    Central PA
    if the turn signals are working the wiring and connections from the turn signal switch back must be ok. it must be the brake light fuse, brake light switch, or turn signal switch that is the problem, or a wiring problem between the fuse and turn signal switch . it could be as simple as the brake light switch being out of adjustment.
    '95 Chevy Silverado 1500
    5.7 V8-NV4500- 3.73 rears
    See My Toys: http://community.webshots.com/user/wdb172454
  3. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    Most likely the brakelight switch - I just replaced mine last weekend. $6.47 including tax from Pep Girls, and it took about 15 minutes. I did end up with the top of my hand held together with tape, after finding a really sharp sheetmetal screw poking through the dash[​IMG], so be careful!!
    ......And knowing is half the battle
    <a target="_blank" href=http://pugsley.alloffroad.com>pugsley.alloffroad.com</a>
