brake lights
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by odee, Mar 8, 2002.
  1. odee
    odee Registered Member
    Feb 5, 2002
    15
    Big Stone Gap Va
    Having problem with my brakelights won't work cheched out switch is ok but no power on either wire [orange and white wires] which is the hot wire and where does it get power from? Is it fused?
  2. dyeager535
    26,982
    191
    Don't believe brakes are fused, and orange is usually 12v constant. (dome lights, cig lighter, etc)
  3. 8_YOUR_H2
    8_YOUR_H2 1/2 ton status
    Feb 20, 2000
    2,663
    Iowa
    What wire are you refering to? The one that goes into the tail light plug or the ones coming out of the fuse box? On my 85 it has green, yellow, and brown wires going to the tail light. If you had your profile filled out we would know a little more about you and your vehicle.
  4. odee
    Feb 5, 2002
    15
    Big Stone Gap Va
    thanks, I had lost power to the orange wire on the brake light switch.
