Brake line fittings... Standard or metric
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by fad2blk99, Jul 27, 2003.
  1. fad2blk99
    fad2blk99 1/2 ton status
    Feb 19, 2001
    860
    Charleston, SC
    I am about to get a set of flare nut wrenches and need to know weather to get strandard or metric to get my stuck and rusted brake lines apart....
  2. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    The lines themselves should be american, the bleeder screws can be either american or metric depending on what the rebuilder has done.
  3. fad2blk99
    Feb 19, 2001
    860
    Charleston, SC
    I'm talking about the flare-nuts on the hard-lines... the flare-nuts that thread into the flex lines (leading to the calipers), into the proportioning valve, etc...
  4. wrathORC
    wrathORC 1/2 ton status
    Apr 27, 2002
    908
    Hancock, MI
    I used SAE line wrenches on my 84's tired lines. The ends out at the front hoses were channel-lock sized though.
    As stated by others, the bleeder screws and banjo bolts were metric.
  5. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    i use adjustable crescent wrench and tap hammer to get mine all the time, easy cake.
    no problem at all.
    and the stuff at the frame rails uses a clip and flare nut threaded into end of hose. thats easy too, can always cut hose or line to help removal use hacksaw or tin snips
    good luck
  6. fad2blk99
    Feb 19, 2001
    860
    Charleston, SC
    Mine are completely rusted and siezed in some parts. I've already had to resort to cuting off the ends and re-flaring some. It's just that I have a lot more to go through, so I think its time to get the "proper" tool for the job and see where that gets me....
    I'm thinking I'm just gonna go with metric since that's what most of our American made vehicles tend to be on the smaller detail part assemblies...
