Brake line help!
Discussion in 'The Garage' started by Chevy305, Apr 20, 2007.
  1. Chevy305
    Chevy305 6 Lug 14bsf Status Premium Member GMOTM Winner
    Jan 23, 2006
    11,230
    488
    New Hampshire
    Ok so I bet some of you may remember the whole stump pulling incedent...
    Well replacing this line is easy and actually the question I have doesn't involve this specific section of line but rather the main rear hard line before the axel on the frame. i notced this after i took my bed off yesterday and wasn't sure. I think the PO might have used compression fittings to replace a section of brake line, but I'm not sure. Here's a picture:
    I just want to make sure that these aren't comprssion fittings because I know that they are a big no no for brake lines...
  2. MuddinManny
    MuddinManny Banned
    Oct 18, 2006
    1,106
    USA
    Hey Glenn,
    I'm kinda funny when it comes to brakes. It's an area I will not take any short cuts in. Had that been my truck, I would have been on the phone to LMC Truck and ordered up the pre-bent replacement line immediately. That jerry-rig is not safe in my eyes and I'd replace the whole line, and give my rig a good bleeding. Again, that's just me and how I operate.
    Manny
  3. Chevy305
    Jan 23, 2006
    11,230
    488
    New Hampshire
    Manny I totally agree! That little section must have been like that for god knows how long and should be replaced. I already have a replacement for the pinched brake line and as soon as my buddy returns my vacuum bleader I will replace it.
  4. MuddinManny
    MuddinManny Banned
    Oct 18, 2006
    1,106
    USA
    Well, I knew already that you had a replacement for the pinched line. I was talking about replacing the hard line where that splice is in place. By the way you wrote your response, it wasn't clear if you were leaving it, or you had a replacement for it already. Like I said before, I'd replace the hole line from the proportioning valve all the way to the back.
    Manny
  5. resurrected_jimmy
    May 23, 2005
    2,241
    back home in Houston
    Its leaking from three different places in that splice, should be enough reason to replace it compression fitting or not
  6. Chevy305
    Jan 23, 2006
    11,230
    488
    New Hampshire
    Not its actually not leaking. What you see there is water after power washing the frame and then blowing it off with my compressor.
    Either way it should be replaced...
  7. Dafey
    Dafey 1/2 ton status
    Feb 10, 2007
    2,675
    Roswell NM
    Dude PLEASE dont drive it untill you replace those 2 comprssion fittings! ! ! !
  8. resurrected_jimmy
    May 23, 2005
    2,241
    Or it could be water from pressure washing your frame and giving it a thorough inspection :doah: :D
  9. MuddinManny
    MuddinManny Banned
    Oct 18, 2006
    1,106
    USA
    x 2,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000
  10. Chevy305
    Jan 23, 2006
    11,230
    488
    New Hampshire
    So are you sure those are compression fittings?
  11. MuddinManny
    MuddinManny Banned
    Oct 18, 2006
    1,106
    USA
    Hi Glenn,
    I think that the point he's trying to get across is whether they are compression fittings (which he feels they are) or not, that set-up is dangerous for you to have. It was never meant to be that way, and is a weak spot in the braking system. Any malfunction there can lead to total brake failure. I agree with Dafey. You've pulled it all apart. Replace the line to be 100% SAFE! Just lookin' out for ya dude!
    Manny
  12. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    If you used a block , like the rear brake lines use on the axle , and capped the unused port and flared both lines to go into the block , would that be a better fix until a new one arrived ?
  13. Chevy305
    Jan 23, 2006
    11,230
    488
    New Hampshire
    I'm not sure what you are trying to say. There is no unused port on the block splitter thingy for the rear brakes.
  14. broncoman6524
    broncoman6524 1/2 ton status
    Oct 31, 2005
    2,469
    chuluota Fl
    um...my project truck had something like that....LOL. ah well its in teh dump pile now...
  15. Chevy305
    Jan 23, 2006
    11,230
    488
    New Hampshire
    I'm a little confused with LMC. It seems they don't carry prebent brake lines for K series trucks. They only list the C series. I don't think that the rear brake lines would be any different but check out the page:
  16. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    I meant , could someone use a rear brake block m which has 3 holes ( one for each side and one for the flex hose ) with the third hole plugged , as an emergency fix if you have a flare tool handy ?
  17. tomford
    tomford 1/2 ton status Premium Member
    Jan 19, 2006
    921
    7
    New Hampshire
    So why are compression fittings a big no no for brakes?
    Thanks for informing the noob...
    Tom
