Brake Line Leak
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by smack, Apr 17, 2000.
  1. smack
    smack 1/2 ton status
    Feb 24, 2000
    277
    Colorado
    I seem to have a leak at my caliper where my brake line connects and after cleaning it I'm wondering if it's okay to use hi-tack or silicone to help seal it or if it's best to just replace the whole caliper.
    Also, as far as bleeding, do I have to bother with the proportioning valve???
    Any help would be greatly appreciated.
  2. CK5
    May 19, 1999
    21,622
    701
    CO
    The first thing to try is, replace the small copper washer (I can not remember the name of those damn things) between the brake line and the caliper. You can get them at any auto parts store for about .20 cents.
    Steve
  3. BIGJ
    BIGJ 1/2 ton status Author
    896
    Central Arkansas
    The washers come with the banjo bolts. You should have a washer on each side of the brake line where it attaches to the caliper. As far as the proportioning valve goes, I don't think you have to mess with it.
    BIGJ
  4. smack
    Feb 24, 2000
    277
    Colorado
    Thanks for the replies,
    There was only the one washer which went on to bold-head side and not one between the line and the caliper. I'll try installing one there and see if that helps.
    I can't see how it could though since the brake line is new and very flat. Maybe not flat enough, eh?
  5. CK5
    May 19, 1999
    21,622
    701
    CO
    Thats the name, Banjo washers, you can buy them seperatly, you just need to ask the counterperson, they usally keep them in a small box under the counter, but bring in the old ones for comparison due to the many sizes they have.
    Steve
  6. smack
    Feb 24, 2000
    277
    Colorado
    A Banjo washer is just a washer with ribs on it right??
    Because where the line connects at the caliper is ribbed -- maybe that's just a cooked on banjo washer?
  7. BIGJ
    896
    Central Arkansas
    The line is supposed to have a ribbed ring where the washer goes (on both sides). The banjo washer is flat.
    BIGJ
  8. BIGJ
    896
    Central Arkansas
    Correction, the washer is smooth (of course it's flat!). Sorry.
    BIGJ
  9. smack
    Feb 24, 2000
    277
    Colorado
    Thanks to everyone for the responses. I haven't had the good fortune to try the banjo washer -- I commute 2 hours to work each way!! -- but I did try one of the silver washers that came with the brake-line kit and that seemed to solve the problem. Maybe they were there for a reason duh.
    Thanks for all the help
    jason
