Brake Line Lowering Kit
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 84k5, Sep 12, 2000.
  1. 84k5
    84k5 1/2 ton status
    May 13, 2000
    2,949
    Dublin, CA
    I was flipping through my Skyjacker catalog and I saw that they sell a little kit to drop your front brake lines down for $5. I would like to install this until I have the money for the stainless steal lines. Does this kit bolt on? Do you have to bleed the brakes? Is this an okay thing to do or is it crap? Thanks.
    Brian
    84k5, 4"Skyjacker lift,33x12.5 Goodyear MT/R, 15x10 Bajas
  2. tRustyK5
    Jul 23, 2000
    36,163
    1,360
    E-town baby!
    I have a 4" lift and relocated lines and it works just fine. I do wheel it quite a bit and have never torn one off(good thing[​IMG]). I also would like the stainless extended lines but have other priorities right now. I don't know if you have to bleed your brakes after or not though.
    Rene
  3. Topher
    Topher Registered Member
    May 12, 2000
    81
    North Texas (DFW)
    I don't know what the Skyjacker kit looks like. But if it's anything like the lowering kit that came with my 4" Tuff Country lift, then all you're doing is lowering the connection point between the main line & the hose that goes to the caliper. My kit basically consisted of a metal bracket that you bolt onto the bottom of the existing bumpstop bracket. Then you have to disconnect the brakeline since it runs through a hole in the frame, and then re-run the lines "under" the frame & reconnect it at the new bracket. Simple to do, but I don't know how well it works since I had opted for some 4" stainless steel lines.
    BTW anytime you disconnect the brakelines, such as in the above procedure, you'll have to bleed the brakes to get rid of any air that may have entered into the lines. Good luck, hope this helps.
    Chris
