brake line nightmare.. pics inside
Discussion in 'The Garage' started by 78Suburban, Jul 17, 2006.
  1. 78Suburban
    78Suburban 1/2 ton status
    Jul 4, 2005
    2,609
    Georgia
    Does anybody even know what part number this brake line is? Its for an IFS truck, and I thought it would fit mine.
    Its for 10mm caliper bolts, so I decided to drill it to 7/16. I was going to get some new copper washers to go against the caliper and bolt. I'm afraid that I didn't drill the hole perfectly straight on one of the lines, as you can see in the pic. I also can't figure out which lines I'm supposed to use on which side, or even exactly how they're supposed to line up against the calipers.
    THE REAL PROBLEM IS that the fittings on the end of these new extended brake lines are simply too thin. The caliper bolt bottoms out before it clamps the line down. So what do I do now? Stacking washers if asking for a leak. I thought about cutting a little off my hollow caliper bolt, but I'm starting to feel like my brake system is going to be very ghetto rigged... not a good thing!!!
    Can I make these lines work? If not, what extended lines can I get for my '78 k20 corp 10, which has a 7/16 fitting??
    somebody please help!!
  2. Scrubby
    Scrubby 1/2 ton status
    Dec 1, 2001
    114
    Boise, ID
  3. grimjaw
    grimjaw 1/2 ton status
    Jun 19, 2004
    944
    Seymour, TN
    I used 1984 Chevette lines on my rear disc conversion. They are about a foot long and cheap.
  4. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    This is for front brakes, not rear
  5. 78Suburban
    Jul 4, 2005
    2,609
    Georgia
    I'm thinking of grinding the hollow caliper bolt shorter, so that it will grab onto these thinner brake line fittings, is this a bad idea?
    Do my holes I drilled look like they're straight enough that they'll even have a chance of sealing (I'm getting new copper washers tomorrow)?
  6. neverendingproject
    neverendingproject 1/2 ton status
    Jul 24, 2005
    1,637
    Tulsa, OK
    As long as you dont cut off too much and clean the bolt, I dont see why you couldnt just cut some off. Building, not buying is the name of the game, and you can do it safely too.
  7. Citizen Rider
    Citizen Rider 1/2 ton status
    May 5, 2005
    1,415
    Plano, Texas
    1. Aslong as the copper washer covers your hole, which it will, you wont leak. Thats what seals it..
    2. Take a grinder, cut off wheel, hacksaw, band saw, something to cut down the banjo bolt, but dont take a ton off.
  8. Scrubby
    Dec 1, 2001
    114
    Boise, ID
    Like I said, I cut mine off. Just like 3/8" or so with a hack saw. Then I ground the cut end to a taper and cleaned up the treads with a die. Works great.
  9. 78Suburban
    Jul 4, 2005
    2,609
    Georgia
    If anybody else needs a short 7/16 bolt, this one is absoultely perfect!!!
